Connect FMC920 to ELM327 bluetooth dongle
I recently got FMC920 and I am trying to get data from my car (Volkswagen Golf 5 2005) via OBD2 dongle via Bluetooth. OBD2 dongle is some off brand. I managed to get them paired (I can see in paired devices when I access setup for my FMC920 device) but no data from car is being sent to FMC920. Do I need some kind of specific dongle that is compatible with FMC920 (what I found in documentation is that it needs to be either ELM327 or STN1110 chips) and if so could I get names of devices that will work on Golf 5 from 2005. Thanks in advance!
Please check this wiki page: How to connect OBD II Bluetooth® Dongle to FMB device - Teltonika Telematics Wiki
Hello yes you are correct usually our client is using ELM327 dongle.
Best Regards
Maynard C
How can you manage to pair elm327 and fmc920?
Have both devices but not figured out how to connect them. Maybe version of configurator is important, I don’t know.
Please find the test report attached
TEST REPORT ELM327 OBDII mini with FMB920.zip (514.6 KB)
