Is it possible to configure fmb125 and fmc125 (APN, DOMAIN, PROTOCOL) with Fota web. I dont want to manually connect the configurator to the device, i want to configure server parameters remotely.
To configure device over the air you would need to upload a configuration file with wanted parameters already configured.
To get the configuration file you would need to open your configurator > Create new configuration > select FMB125 or FMC125 > Select latest configuration > Enter the required parameters according to your needs > Click “Save to file” in the top of configurator. > save the file to your PC.
You can also download the current device configuration from FOTAWEB and open it inside the configuration ( “load from file” button ) and only change the needed settings. Afterwards save the file to your PC as mentioned before.
Now that you have the file upload your file on FOTAWEB by selecting “Files” tab on the left and clicking “upload” in top left corner. Select “File type” as “Configuration”.
Now go to “Devices” tab on the left, select the device you want to create and click “create task” button.
Create the task to upload configuration file and select the configuration file you have just uploaded to FOTAWEB.
Now that the task is queued wait until device connects to FOTWAEB or send and SMS message to device force FOTAWEB connection:
SMS command without login/pass: “web_connect”
SMS command with login/pass: “loginpasswordweb_connect”
This will force the device to download new configuration.
Best regards
