Hi team, want to check I configured DIN 3 (grey wire) correctly to register for device FMC 130 when water pump is running in vehicle.
I set priority level low and operand as when change. Pump will send a positive trigger when activated.
Are there other fields I have to change in the configurator?
I suggest to verify that the voltage level and signal from the pump are compatible with the device’s requirements before connecting it, and if it fall within the supported voltage range,
You can check the incoming voltages while the pump is active or inactive using a multimeter to ensure they are within the device’s specified range.
About the priority and operand; if you configured low then select the operand on Monitoring, as with this ; the values are recorded only and no additional event alert will send to the server,
