Configurator for FMB003
I have downloaded a configurator for FMB003, but its says that is not suported, when I connect the tracking device.
Which configurator should I use?
Hello @autospy ,
Please check the firmware of device.
The configurator you downloaded might not be compatible with the current firmware of the device and when the configuration does not match the current version, it will show as not supported.
Download the configurator from link Teltonika Configurator versions - Wiki Knowledge Base | Teltonika GPS
Regards
Maryam
This topic was automatically closed after 10 days. New replies are no longer allowed.
