Configurator Bluetooth 4.0 and I/O Panel
I use FMM130 to collect data from various BLE devices. With Codec8, i can transfer three parameters (Battery, Humidity, Temperature) of 4 different BLE-devices.
In configurator Ver. 1.7.30, the data field for “BLE Battery #1” is missing in the I/O panel. So only 11 parameters can be used.
In configurator Ver. 1.7.72, in the Bluetooth 4.0. Panel, the advanced setting for BLE_Connection_#4 is missing. (MAC Address etc.). So only 9 can be used.
Is there a configurator-version, in which both panels work properly, so that all 12 parameters can be used?
Leonhard
Please try to move the scroll bar down for the config version 1.7.72
Kindly make a test using the firmware 03.29.00.rev.14 if your FMM130 is having a FMM130 with BG95-M3
Download link: https://wiki.teltonika-gps.com/view/Special:Redirect/file/FMB.Ver.03.29.00.Rev.14_and_configurator.zip
Or if does not work please try to the TCT.
Wiki page: Getting started with TCT desktop application - Wiki Knowledge Base | Teltonika GPS
Download link: https://github.com/teltonika-telematics/tct-releases/releases/download/v.1.1.80/TelematicsConfigurationTool.Setup.1.1.80-windows-x86_64bit.zip
Best Regards
Maynard C
This topic was automatically closed after 12 days. New replies are no longer allowed.
