I can not manage to find the configurator to use the eye sensor with a FMB920. I have tried several versions, but none of them show the section that we see at the manuals
Download the configurator and firmware from link Firmware versions - Wiki Knowledge Base | Teltonika GPS
The configurator have option to configure eye sensor under the Bluetooth 4.0 setting
Please find more details regarding eye sensor and device’s configuration from link EYE SENSOR / BTSMP1 - Wiki Knowledge Base | Teltonika GPS
Regards
Maryam
Configurator is ok now.
But there is some thing wrong
At the eye app tha data is ok
At the configurator " bluetooth 4.0" tab tha data is ok.
But at the I/O tab on the configurator and on the Telyonika App, the data is freezed an wrong.
In the screenshots you shared, it shows the error code, and there is no sensor data can be seen
Uploading: image.png…
check the error code you received, these error means that sensor not found
Please try to enable the Non-stop scan under Bluetooth 4.0 < common settings so device will scan data continuously without any delay,
Also keep the latest firmware update in device, download from link Firmware versions - Wiki Knowledge Base | Teltonika GPS
Regards
Maryam
