Composed SMS format with % does not work
I have FMC130 and trying to add custom SMS format that will be sent to a pre-defined SIM card number when AIN2 enters and exits a range. I typed [IMEI %imei, Date %date, Ext_Battery %exv, AIN2 %ain2]. However, i only get the value of %ain2. The rest of the % placeholders do not work. It only works when I type [%imei %date %exv %ain2]. Wondering what are the conditions here for syntax.
The issue here is that you are using commas with placeholders.
You cannot use them together like %imei,
Instead of a comma, you can use a space, or add one space before the comma.
For example, both of the following options will work for you:
IMEI %imei , Date %date , Ext_Battery %exv , AIN2 %ain2
IMEI %imei Date %date Ext_Battery %exv AIN2 %ain2
Naveen
I see now the mistake. Thanks for the help.
