I would like to clarify whether an Iridium Edge terminal purchased from a supplier other than Teltonika can be used with the FMC650.
The Iridium Edge terminal I have purchased is already activated. Could you please confirm whether it is compatible with the FMC650, or whether it is necessary to purchase the Iridium Edge directly from Teltonika?
6 days pass no response from teltonika
Good day,
The supported Iridium Edge for our product can be found in this datasheet.
If the Iridium Edge is the same as yours, you may test and integrate the SBD by following the instructions here.
Kindly note that SBD(Short Burst Data) requires a supported firmware to proceed, kindly update the device firmware to support Iridium Edge.
Here is the link where you can access to our Iridium Edge solution wiki:Iridium Edge - Teltonika Telematics Wiki
Cheers,
Victor How
