Change data acquisition with geofence
I am looking on the FMM13A and FMM920A tracking devices for North America.
I would like the tracker to send 1 position/day when the vehicle is in a manual geofence, and 1 position/15s when the vehicle leaves the zone.
Is it possible to do it with Teltonika devices ?
Thanks in advance.
Hello @fclaude,
I hope you are doing well. Unfortunately, the Data Acquisitions settings were based on Movement status and could not generate records based on Geofence set on the device.
On the other hand, additional record could be generated/set based on the speed values read by the device through Manual Geofence.
Hope this helps.
Patrick S.
Thank you for the precision !
Regards
