Over bluetooth connection to charger works.
OCPP connection also works (with schema issues but that is different topic). So Wifi is working fine.
However I cannot connect to it over the internet using TeltoCharge app (neither local Wifi nor internet)
Thank you for reaching out. EVC1 model stations supports communication between mobile application and EVC1 station only through Bluetooth connection. Wi-Fi and lan connections are used by OCPP communication. Although EVC2 supports communication between mobile application and charger over the Wi-FI, but it’s only on local network. My apologies about confusion.
Sincerely,
Dominic
