I’m struggling to connect my GH5200 to my computer.
I followed the step on the wiki, turned on the GH5200 and installed the latest usb drivers but nothing happen when I connect the device to my computer. I also tried doing it by bluetooth too but it connect for a few miliseconds and got disconected right away. And the configurator seems to show no device connected.
Normally, you should Turn on your device by holding the power button for around 7 seconds then connect device to computer using Micro-USB cable. However, if you did not install the Teltonika USB Driver the device would not be recognized at all - suggesting you to open the Port Manager of your PC to confirm that the device is properly recognized by your PC, otherwise try to reinstall the Driver.
