CANbus simulator
I’m testing various telematics devices, particularly FMB130. Working well with basic functionality but I want to simulate CANbus data collection. Any idea how I would go about this? Basically connect the CAN H and CAN L wires to something which will offer an output simulating fuel/battery levels, engine speed etc, which I would then read remotely on my flespi instance.
TIA
Hi @vincent.okane
Good day, If you are going for a CAN simulator kindly check for similar sites like reddit, github, etc, I will keep this topic open for some time so that other members can also see and suggest on your queires.
Note: If you want a real CAN data you can pair FMB130 with LVCAN or ALLCAN300 get the schematic diagram from us and connect it according to the schemes put the correct program number and enable the parameters that you need in the CAN Adapter IO.
Wiki page link: CAN Trackers & Adapters - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
Best Regards
Maynard C
