Hello, can FMB140 works on Toyota Sienna? if yes, I need the CAN wiring diagram.
Hello @Sagacious,
I hope you are doing well. Toyota Sienna is on our Vehicle supported list, you may check the complete vehicle list on this link below.
FMB140 Supported List: https://wiki.teltonika-gps.com/images/4/44/FMB140_LV-CAN_List_2026_02_04.xlsx
On the other hand, you may try connecting the CAN1 on OBD Pin 6 and 14 while CAN2 High only on Yellow 10 Pin Connector (Pin 10 red/purple), you may keep the CAN2 Low not connected.
Hope this helps.
Patrick
