CAN-CONTROL generates no data on Peugeot Expert (program 13114 confirmed) — need connection scheme
We have a CAN-CONTROL adapter paired with an FMC130 that does not generate any
CAN data, despite the correct program number being set and confirmed. We have
exhausted the software side and believe the issue is the physical CAN bus
wiring. We would like your help to confirm the correct connection scheme.
Subject: CAN-CONTROL generates no data on Peugeot Expert (program 13114 confirmed) — need connection scheme
=== HARDWARE ===
- Tracker: FMC130
CAN adapter: CAN-CONTROL
lvcangetinfo → Prog:13114 SWDate:230214
ould you please provide:
1. The official CAN-CONTROL connection scheme for program 13114 for this
vehicle (Peugeot Expert 2016=>, VIN VF3VBBHXHJZ042180): which connectors,
which pins, and which wire for each of the required CAN buses.
2. Confirmation of how many CAN buses must be connected for AVL 87/105 to work,
and whether an OBD-only connection is insufficient for this vehicle.
3. Any known issues with program 13114 on this vehicle.
Good Day,
Unfortunately, the wiring schematic cannot be provided on the public community forum. Kindly contact your sales manager and they will assist you with creating a partner portal ticket.
Thanks, and best regards,
Imran S.
