Hello Everyone,
I have a Fmb 130 + Can Control. I want to read total fuel composition, hand brake status and lighting status. How can read these data. I didn’t see it in the configurator. Finally i want to close car window and i use to lvcanclosewindows:10 command but it not working. Teltonika return this response : “invalid open window cmd value”. How can execute this command ?
Hi Taha,
Good day, Thank you for reaching out to Teltonika Telematics Community Forum!
Please identify your vehicle model/manufactured date and then check in our supported vehicle list: CAN adapter supported vehicles - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
Select which CAN adapter you have.
We have 2 types of parameters we called it Flags and General parameters ,
Flags
General Parameters
+ sign means that the vehicle supports that parameter and blank means it does not support it.
For parsing the Flags you can check this link: FMB110 CAN adapters - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
For checking the SMS/GPRS commands for CAN-CONTROL you can check it here: FMB SMS/GPRS Commands - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
Note: Parameters availability depends on the vehicle brand/year make.
If you have doubt or you need further assistance please contact your sales manager.
Maynard C.
