Buzzer for overspeeding FMB device
Hello Team
Just see if teltonia has it own buzzer device for overspeeding.
Can you please help me with model that are compactible with fmb devices?
Thank you
Hello @evariste
The device has feature Over speeding , where Dout control is available under the scenarios
You can connect an external buzzer to the digital output and set up a speed limit. The buzzer will beep once the device crosses the configured overspeed limit.
Regards
Maryam
Hello Maryam
Thank you for your feedback but do you have Buzzer model that i can use?
The tracking device i have is FMB225, is it possible to use relay and buzzer at same time? or I need to use a device with 2 Dout? like FMB202. Sorry i am a beginner
Hello @evariste,
Any buzzer that you purchase from the market can be used with the digital output of a device.
However, if you are using both buzzer and relay then you need to use device with 2 Dout,
As single digital output cannot be used for both.
Regards
Maryam
HELLO Maryam
Thank you for you support. I will look for a device with 2 Dout
This topic was automatically closed after 22 days. New replies are no longer allowed.
