I’ve read the wiki and cannot figure this out.
UPDATE: Do I need to pair with the device to get magnet (or temperature) data? The docs are unclear
I am trying to do something that is very simple. I want to extract the presence/absence of a magnet for the EYE sensor. I am using an ESP32s3 microcontroller to gather this data via BLE. This is a new EYE device without any additional configuration. The simple application code for the esp32s3 is written in c (see code below).
No matter what I try, active or passive scanning, I always get data like this:
Advertisement Data (len=31): 02 01 06 03 03 aa fe 17 16 aa fe 00 e2 00 00 00 00 00 00 00 00 00 00 7c d9 f4 10 bf 8f 00 00
Eddystone-UID: TxPower=-30 dBm, Namespace=00000000000000000000, Instance=7cd9f410bf8f
In other words, I get the Eddystone-UUID, but nothing I can interpret to gather the magnet info. What am I doing wrong?
For completeness, here is a test snippet that looks at specific EYE mac address:
#include <esp_gap_ble_api.h>
#include <string.h>
#include <stdio.h>
static void esp_gap_cb(esp_gap_ble_cb_event_t event, esp_ble_gap_cb_param_t *param) {
if (event == ESP_GAP_BLE_SCAN_RESULT_EVT) {
esp_ble_gap_cb_param_t *scan_result = param;
// Filter by MAC address: 7c:d9:f4:10:bf:8f
uint8_t target_mac[6] = {0x7c, 0xd9, 0xf4, 0x10, 0xbf, 0x8f};
if (memcmp(scan_result->scan_rst.bda, target_mac, 6) == 0) {
// Process inquiry result event
if (scan_result->scan_rst.search_evt == ESP_GAP_SEARCH_INQ_RES_EVT) {
uint8_t *adv_data = scan_result->scan_rst.ble_adv;
uint32_t adv_data_len = scan_result->scan_rst.adv_data_len;
// Debug: Print raw data
printf("Advertisement Data (len=%u):", adv_data_len);
for (uint32_t i = 0; i < adv_data_len; i++) {
printf(" %02x", adv_data[i]);
printf("\n");
// Parse BLE advertisement fields
int offset = 0;
bool found_magnet_data = false;
while (offset + 1 < adv_data_len) {
uint8_t field_len = adv_data[offset];
uint8_t field_type = adv_data[offset + 1];
if (field_len == 0 || offset + field_len + 1 > adv_data_len) {
printf("Error: Invalid field length %u at offset %d\n", field_len, offset);
break;
// Manufacturer-specific data (type 0xFF, Teltonika ID 0x089A)
if (field_type == 0xFF && field_len >= 4 && offset + 5 < adv_data_len) {
if (adv_data[offset + 2] == 0x9A && adv_data[offset + 3] == 0x08 &&
adv_data[offset + 4] == 0x01) { // Teltonika ID + protocol version
uint8_t flags = adv_data[offset + 5]; // Flags byte
printf("Teltonika Sensors data found: Flags=0x%02x\n", flags);
found_magnet_data = true;
if (flags & (1 << 2)) { // Bit 2: Magnet sensor active
if (flags & (1 << 3)) {
printf("Magnet ON (magnetic field detected)\n");
} else {
printf("Magnet OFF (no magnetic field detected)\n");
} else {
printf("Magnet sensor inactive (Bit 2=0)\n");
break; // Found magnet data
// Eddystone-UID (type 0x16, UUID 0xFEAA)
else if (field_type == 0x16 && offset + 4 < adv_data_len &&
adv_data[offset + 2] == 0xaa && adv_data[offset + 3] == 0xfe) {
if (offset + 21 < adv_data_len && adv_data[offset + 4] == 0x00) { // Eddystone-UID
printf("Eddystone-UID: TxPower=%d dBm, Namespace=",
(int8_t)adv_data[offset + 5]);
for (int i = 0; i < 10; i++) {
printf("%02x", adv_data[offset + 6 + i]);
printf(", Instance=");
for (int i = 0; i < 6; i++) {
printf("%02x", adv_data[offset + 16 + i]);
printf("\n");
offset += field_len + 1;
if (!found_magnet_data) {
printf("No Teltonika sensor data found in advertisement. Try active scanning for Scan Response or verify sensor configuration.\n");
void app_main() {
esp_ble_scan_params_t scan_params = {
.scan_type = BLE_SCAN_TYPE_PASSIVE, // Use passive scanning
.own_addr_type = BLE_ADDR_TYPE_PUBLIC,
.scan_interval = 0x100, // 256ms
.scan_window = 0x100 // 256ms (match interval for continuous scanning)
esp_ble_gap_set_scan_params(&scan_params);
esp_ble_gap_register_callback(esp_gap_cb);
esp_ble_gap_start_scanning(0); // Scan indefinitely
