There is no confirmation that BCST-72 is supported by Teltonika device according to Wiki.
However, you may test the BCST-72 scanner with the same configuration setup as BCST-70 and see is it working for you since the the Barcode ID is presented in variable bytes. Below are useful links for your reference in testing:
If you encounter any problems, kindly reach out to sales on Contact us to gain access to Partner Portal.
