Battery connector for 621230
Hi!
Battery died(621230) for my tracker thus where can I get crimp terminals & connectors for it - as I want to upgrade it to higher capacaty rather than default 170mah.
Googled for many hours - it isn’t molex, it isn’t JST, also it isn’t hirose. Did really teltonika “went so far” to create their own propriatery plug & terminals?
Thanks.
Hello
The battery can be connected and disconnected from the terminal connector embedded inside the device’s PCB
Kindly check more details from link FMC920 First Start - Wiki Knowledge Base | Teltonika GPS
Regards
Maryam
Hi! @Maryam,
I did not ask how to disconnect/connect battery. I asked - what is the crimp terminal & connector used for it.
Thanks.
Hello
These components are from Teltonika and are not available on the market for purchase or replacement in case of a fault.
Please contact the sales Manager at Teltonika to check the procedure for component replacement.
If you don’t have any contacts with our Sale managers, please contact with them on our official website https://teltonika-iot-group.com/ and click on “Contact Us” button. When you will click, please fill the form and submit it.
Regards
Maryam
Hi @Maryam
thanks for clarifying. I have contacted using form you have linked.
