Thanks for the reply.
- Yabe is running on my laptop and there is nothing connected LAN and it using dhcp. Yabe’s local endpoint is 10.100.16.10.
- Yes, I chose “No rewrite” to internal port so it is using same port as external, right? This works with devices that use direct communication, but not if communicating through BBMD device (Can read the objects from BBMD device itself but not the other like the LON device in this case).
- What of these (eth0, eth0.1, eth0.2, br-lan) is used for VPN then?
Here is picture of the BACnet settings in RUT right now. I’ve tried all kind of combinations but haven’t got it working. How should settings look like?
