Hi. I just purchased a Teltonika fmb920. I may not use my vehicle for a long period of time, so with previous GPS trackers what I did is I connected GND to ignition to avoid vehicle battery drain when not using the vehicle. Is this also recommended with your device? I’m fine with it not tracking data when not in use.
Is there an alternative, like a way to stop the device if no ignition and the built-in lipo battery is dead?
Thank you.
Hi Kajuma,
Thank you for reaching out to the Teltonika Telematics Community forum!
To avoid draining your vehicle battery you can enable the sleep modes
To know more please click here: FMB920 System settings - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
You can also set the data acquisition according to the modes: FMB920 Data acquisition settings - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
Maynard C.
