ATC700 not supported in TCT
I recently received an ATC700 and I am trying to configure it using the Telematics Configuration Tool (TCT), but the device shows as “Not supported”.
Device details:
  • Model: ATC700
  • Firmware: 3.7.0-rc.25
  • TCT Version: 3.0.30+ad234617
I have tried the following:
  • Connecting via USB
  • Sending SMS commands (getinfo, setparam etc.) – these work fine
  • Configuring server settings via SMS (APN, IP, port) – parameters are saved correctly
  • The device has GPRS connectivity (confirmed via getstatus)
  • However, the device does not connect to my Traccar server on port 5027
My assumption is that the RC firmware (3.7.0-rc.25) is causing the “Not supported” message in TCT and may also be preventing a proper GPRS connection to the tracking server.
Has anyone else experienced this issue with the ATC700 and RC firmware? Is there a way to update the firmware without FOTA Web access?
Thank you!
Good Day,
Please use the link below to add the user key in the TCT tool in order to use the ATC700 device via TCT tool. Let us know, if you still have issue in connecting with device via TCT tool.
Ashutosh S.
