Good day, ![]()
We still have a AT1000 in the field but the computer with the AT1000 configurator has been replaced with a Windows 10 machine.
Can someone please send us the drivers and AT Configurator?
The files are no longer on the Teltonika site as it is a EOL product.
I seem to have found VCP_V1.3.1_Setup_x64.exe & AT Configurator-20110803-v2.0.2.9 but I receive the following error and the application closes when I try to read from flash or read the IMEI. It seems that when I press device startup that it does indeed connect and displays the message device started. I guess the firmware is not recognised, maybe too old for the configurator?
I also found AT1000 Configurator 0.x.x.17 but I am having the same issues, although this time it recognises the firmware as 3.00.01. Does anyone have AT1000 configurator v1.3.00.x ?
Can this be a hardware issue? Seems the driver is correctly installed.
Maybe an update to a newer firmware could work with the AT1000 updater. Does anyone have access to these?
Anyone have any ideas?
Hi @donatosd
Good day,
Unfortunately, we no longer have a configurator for the AT1000, as the device reached its end of life (EoL) quite some time ago.
I will keep this topic open for a while in case anyone has the file and can share it with you.
Best Regards
Maynard C
