Assistance with Connecting FMC130 GPS to BMW M4 2024
I hope this message finds you well. I am seeking assistance with connecting the FMC130 GPS device to my BMW M4 2024. Could you please provide guidance on the following points?
  1. What is the recommended method for connecting the FMC130 GPS to my vehicle?
  2. Will installing this device affect the warranty of my BMW M4 2024?
  3. Are there any specific GPS models you would recommend for my vehicle?
  4. What additional accessories, if any, are necessary for the installation?
  5. Do you recommend connecting a relay for ignition cut-off, or are there other accessory options for this purpose?
Thank you for your support.
Best regards
  1. I’ve included links below to a video and an article that will guide you on how to connect your Teltonika device to your vehicle.
FMC130 installation recommendations: FMC130 First Start - Wiki Knowledge Base | Teltonika GPS
Video installation tutorial: https://www.youtube.com/watch?v=XfWtFsYvUms
  1. If you cut/trim the wires from your vehicle for connection, it may affect the warranty. Please check our video tutorial for proper device installation.
  2. It depends on your requirements for example if you need extra analogue/digital connections, etc. you would need to go for our advanced tracker like FMC130.
    Please check the pages below, you can also compare each device according to your requirements
Teltonika Wiki page: https://wiki.teltonika-gps.com/view/Main_Page
Product Categories: World-leading GPS Trackers For Aftermarket And OEM Applications
4/5.It depends on your requirements if you require extra accessories please visit our use case page on our website to determine which accessories are necessary to meet your needs
FMC130 use case Use Cases Showing How Telematics Products Help In Various Industries
All use cases: Use Cases Showing How Telematics Products Help In Various Industries
Accessories page: https://wiki.teltonika-gps.com/view/Accessories
CAN adapter: CAN Adapters - Wiki Knowledge Base | Teltonika GPS
Eye sensor/EYE Beacon: EYE SENSOR / BTSMP1 - Wiki Knowledge Base | Teltonika GPS
Note:
For basic tracking functionality, no extra accessories are required, however, if you plan to use a relay for immobilization, you would need to acquire a device for driver authentication (1 wire reader with iButton or Bluetooth beacon) and you would have to source the relay yourself.
FMC130 Wiring Diagram: https://wiki.teltonika-gps.com/images/0/0a/Wiring-scheme-FMC130.jpg
Immobilizer wiki page: https://wiki.teltonika-gps.com/view/FMC130_Features_settings#Immobilizer
1-Wire reader for immobilization scenario: 1-Wire RFID Reader – Accessory For Fleet Management Devices
I hope this helps. Please let us know if you have any other questions.
