Actual Operador Code 0
Hello
I am configuring GPS FMB920 but in GSM Info the Current Operator Code shows 0, it doesn’t raise the operator code, I checked the phone line and it isn’t the problem, the same line works normally in another GPS, what can happen to not raise the operator code?
Hello @fernandovillca
Kindly update the firmware of device and then try to test.
You can download the latest firmware from link Firmware versions - Wiki Knowledge Base | Teltonika GPS
Be noted that the device FMB920 only support 2G network connectivity.
Regards
Maryam
This topic was automatically closed after 10 days. New replies are no longer allowed.
