Is it possible to connect the ACREL ACR10R smart meter to the TELTOCHARGE EVC101 to initiate dynamic load balancing?
Wiki shows a supported 3-phase option, but the wiring diagram is missing.
ACREL ACR10R 1-phase option has RS485 connection A+ B- on 21 and 22 pin.
Does anyone could give some suggestions on this?
Each model of the smart meter is implemented separately.
I can’t confirm that your selected model will be working, because it’s not in our wiki list and it means it’s not tested. Most likely it will not work, because each meter has it’s own identification modbus register.
Anyway, on the side of the smart meter there should be a label with A+ and B+, you can try to connect to our charging stations. If you will get unidentified energy meter, it means that charging stations sees the data, but can’t understand. I would suggest to pick exact model that is listed in our wiki page
