Accidentally sent cfg with authorized numbers list
I have accidentally sent the configuration with authorised numbers; the numbers do not belong to me, they were added because of a previous test. The device is already installed. Is there any workaround to clear the list?
Fota web/GPRS commands?
I have the configuration with me, I know the phone numbers, also the SMS login and password
HW: FMC650
Thank you for your message,
If the device is already in your FOTA WEB account and it’s Online, you can:
  1. Prepare a corrected configuration using the Teltonika Configurator (with the Authorized Numbers removed or changed).
  2. Upload that CFG to FOTA WEB and assign it to the device.
  3. Either wait for the next automatic device connection to FOTA Web (usually every 12 hours) or trigger an immediate connection by sending the following GPRS command from your Server :
web_connect
  1. Once the task is completed, the new configuration (without the wrong numbers) will be applied.
Alternatively, it’s possible to directly overwrite the existing Authorised Numbers List using a GPRS command that will need to be sent directly from your Server to the FMC650. This requires Codec 12 (Protocol for sending GPRS commands) to be already implemented on your Server. Let me know if you’d like more clarifications regarding this option.
Best regards.
