3x RUT200 : 2 work and 1 not
I’ve actually an issue with one of three RUT200 router 4G.
I’ve setup all three and one doesn’t work : you can connect to the wifi with a laptop but you can’t reach internet pages.
I’ve already reset it, and re-setup it : same issue.
I compared the configuration of the router that isn’t working with the configuration of one of the other two that are working: they are strictly identical (I even checked the firmware version : all same).
I was thinking maybe it’s the SIM card that got an issue, I swapped two SIM cards between the router that doesn’t work and one that does. Always the same router doesn’t work.
I’m stuck; I’m out of ideas, other than thinking that one of my three routers is simply defective.
Do yo have any ideas ?
Thank a lot
BrunoP
Hi…
Have you try to disable IPv6 at mobile, wan and lan?
Yes I tried to disable IPv6 (I found this solution on internet) but it changed nothing in my case, unfortunately.
AT the troubleshooting… Can you do a ping to 8.8.8.8?
Can you check at status > Mobile?
Signal? Good?
Ping doesn’t work
Mobile status : connected
Signal : good
I can do print screen tomorrow if needed.
I’ve done a factory reset of the device, setup it again and it still doesn’t work :frowning:
Is it possible that this one is defective ? How does the warranty work ?
Hi…
You need to contact the vendor of this device.
Ok, I will do this. Thank you a lot Marcelo for your support.
