Won't Recieving MBus Data with Firmware 7.08 TRB 143
With the latest firmware update 7.08 there is a problem when receiving MBus files. Since the update, I have some Mbus meters that only reach “succesfull request” two or three times when the router is restarted and then fail. Can anyone help me? The troubleshoot file is attached.
Unfortunatly i can’t attach the file.
I do have the same problem. If I did upload the new firmware first, then I couldn’t readout the wired Mbus, also the scan did work sometimes. It mentioned something about address allready used…
On an other TRB143 I hade everything running, and then after the firmeware update it first keept running. Now it’s not working anymore, I didn’t figure out what configuration made the troubles.
Sometimes it seems, like the M-Bus Master service isn’t available.
help!
For now, it seems, stable version for Mbus is TRB1_R_00.07.07.3_WEBUI.bin
