Wireless RS485 over WiFi
Is it possible to use two RUTxx devices to replace a serial RS485 cable connection and convert this to a transparent wireless serial connection?
The following image should clearly show what we woudl like to do with two RUTxx devices:
It is possible to enable serial communication between two serial devices using the Serial Over IP functionality. We have a configuration example available here.
You can configure one RUT in WiFi client mode to connect to the second RUT over WiFi. One RUT will be a server in the Serial Over IP configuration, while the other device will be a client.
