Hi can you please explain what features are not in use while using pass-through mode for mobile sim?
In passthrough mode, the device will pass the mobile IP address to the first (or specified) connected LAN client, while still keeping NAT active for the RUTXR1 and the other LAN clients.
While I’ve not tested this personally, BGP should still work even with passthrough mode. BGP routes should be reachable NAT clients, but you may experience some issues with the client that receives the IP address of the mobile interface.
Perhaps you could expand on your solution and provide a topology?
