Wifi extend RUTX12
What would be teh best Wifi extender with a RUTX12 ? I’d like to have the same SSID.
Is that a mesh network that I need ?
RUTX10 is a good and the cheapest solution ?
I seen this documentation, but not really sure : RUTOS relay / Wi-Fi extender / repeater / bridge configuration - Teltonika Networks Wiki
Thanks !
Thanks for reaching out!
RUTX10 has no mobile capability and one of the most chosen device when it comes to WiFi Mesh.You can find detailed informations from here.
But if you just want to extend your WiFi coverage you can also choose one of the Access Points also. Our TAP series. Informations can be found here.
Caner
