I’d like to monitor multi compartiment fuel tank, the tank may have 6 compartiments, and for each compartiment I want to report temperature and fuel level.
The compartiement height is 2.5 meters max.
Which GPS device is recommended to support 12 sensors (6 for fuel level and 6 for t°)?
If possible also which sensors should I use, I’m thinking for ultrasonic sensors for fuel level detection.
Thank you in advance.
Hello @slah,
I hope you are doing well. Suggesting you to check the FMX125 RS485 LLS Protocol which might help you connect more Fuel Level sensors.
For more information you may refer to this link: FMC125 RS-232 and RS-485 - Teltonika Telematics Wiki
Hope this helps.
Patrick S.
