Where is the zerotier zone defined?
On my RUTX11, os version RUTX_R_00.07.06.3
I installed zerotier from the Services menu and am using it successfully so far.
In Network / Firewall / General Settings / Zones
I can see three zones defined:
wan, lan, zerotier
I can see where the wan interface is defined:
Network / WAN / WAN / Physical Settings & Firewall settings
I can see where the lan interface is defined:
Network / LAN / lan / General Settings / IPv4 address & Physical Settings & Firewall settings
BUt, where is the zerotier interface defined?
there should be at least an IPv4 adress range.
thanks, mc
While there is nothing in the RUTOS gui,
I have found in /etc/config/firewall
config zone '42'
option name 'zerotier'
option input 'ACCEPT'
option device 'zt+'
option output 'ACCEPT'
option forward 'ACCEPT'
Maybe this is sufficient?
I also thought there also be a statement in /etc/config/network
something like:
config interface 'zerotier'
option ifname 'zt+'
or in the gui, an entry in network / lan interfaces?
I found the answer in
community.teltonika-networks.com/42785/zerotier-network-missing-from-zone
(on my 87th search).
1 It seems it is not necessary to create an ‘interface’ zerotier,
one can just use the ‘zt+’ device.
2 the option name ‘zerotier’ creates the zerotier zone.
