HI
Yesterday I upgraded the firmware of my Rutx50 to the RUTX_R_00.07.12_WEBUI.bin version and suddendly can not access via http from wan or mobile
The router is 300 km from me…
Luckily I have a pc on the back network with google remote and went inside the router (as in local mode) to check it out.
All was aparently in order.
I have also a zerotier network that usually works perfect, but in this case failed too.
Revised the firewall, the portforwarding, the administration… everything was ok
Reading the topics also I went inside the cli and wrote some sentences as proposed. Nothing
I have defined the external access though the port 8080. That worked before but not now.
Do not know what to check now.
Any help will be much appreciated.
