Hi all,
When using a TRB255 in PASSTHROUGH mode so it can provide failover for basic services, I’m unable to access the WebUI.
I suspect I have 2 issues.
- Configuration of the TRB given the google hits in the old forum including one which was marked as solved.
- Router configuration. I can ping the TRB from a diagnosis feature within the router, but not from a machine attached to the LAN
(It does exactly what I want it too with a PC directly attached)
Cheers
Try pinging/accessing the IP address that you see when you execute ipconfig/ifconfig on your device in LAN. Specifically, try using the default gateway IP address on the appropriate interface.
regarding your case and 1-st issue:
- Check out my topic from old Forum, which is available as RO - this describes issue resolved with Firewall->Port Forwarding for remote access fix after setting up Passthrough mode at RUT240, but basically I guess this will be the same case with TRB255. Hope this will help you.
Robert.
