Webpage showing wrong IP
I could not access to RUT955 with RUT9_R_00.07.02.7 fw version from outside.
I spent many time to check firewall rules and on my laptop (connected to lan port), I can see IP 2.193.164.77/32 under MOB1S1A1 (MAIN) form.
If I login in ssh ifconfig tells me wwan0 has 2.193.193.218.
I solved rebooting RUT955.
Is this a known bug?
It appears you are using an old firmware version, which is likely the cause of the issue. I recommend upgrading your RUT955 to the latest RUT9_R_00.07.06.13 firmware version. Always using up-to-date firmware is important as it includes issue fixes and improvements. You can download the latest version here RUT955 Firmware Downloads - Teltonika Networks Wiki .
Hope this helps!
