I would like to route 2 Ip addresses through the Wan interface on my Rut241. On the customer network side, Device 1 should then be accessible under the IP address 10.163.29.210 and Device 2 under 10.163.29.211. Device 1 normally has a static IP address 192.168.0.1 and Device 2 has the IP address 92.168.0.10. (See also the attached picture). How do I set up this scenario on the router?
Based on the provided topology, it would be achieved using Port-Forwarding. If you want to reach the WebUI of each device, it will be reachable via the WAN IP of RUT241. Let say WAN IP is 10.163.29.211.
