I setup VRRP btwn RUTM50 (SW on RUTM_R_00.07.12.3) and Digi WR21 which is working but looking for best practice. I only setup Group ID and virtual IP. All other settings is default and virtual MAC is disabled. Thanks
The key setting is to configure the correct priority value. The router with the higher priority (e.g., 255) will act as the Master, while the router with the lower priority (e.g., 100) will function as the Backup. All other settings should be identical on both routers.
For more details, please refer to our wiki page: VRRP Example.
Let me know if you have any questions!
Hi Marija
I already looked at this VRRP example which seems to follow the general config guide. I’m looking for more details and best practices. Thanks
