VPN with L2TP over IPsec Connected, no Ping possible
Hi There,
i have a VPN with L2TP over IPsec configured like in this tutorial:
https://wiki.teltonika-networks.com/view/L2TP_over_IPsec
I have a RUTX14 on the Server Side, and a RUT906 on the Remote/Client Side.
The VPN shows connected on both sides.
Then i test pinging from the Server side (RUTX14, from the WebUi - system - maintenance - troubleshoot). I can Ping the virtual IP of the Client RUT906. But i cannot ping the IP of the RUT906 or the Laptop connected to the RUT906. They are all in one Network (192.168.10.x/24)
What did i do wrong?
Thanks, Stefan
I recommend you try creating a static route on the RUTX14. You can find detailed instructions and more information about routing on our wiki page: RUTX14 Routing - Teltonika Networks Wiki.
In your case, the Interface will be VPN, the Target will be RUT906 LAN (192.168.10.0), and the Gateway will be the virtual RUT906 IP.
Hope this helps!
