USSD commands in crontab RUT241
I’d like to have a daily e-mail with the mobile data usage.
For this I try to use crontab and gsmctl -U command.
But…
When I run command:
gsmctl -U *100#
then I get the correct response.
But when I try do the same daily in crontab using the following:
0 6 * * * gsmctl -U *100#
then I get a response like this:
+CME ERROR: retry operation
When I browse the syslog I see:
cron.err crond[7090]: USER root pid 704 cmd gsmctl -U *100
Does it meat that there’s some issue with the last character “#” and should it be written with some prefix?
Have you tried escaping with slashes like so?:
gsmctl -U \*100\#
You can also put the command into a script. Create script:
vi /etc/yourscript.sh
Press ‘i’ to start editing. Paste:
#!/bin/bash
gsmctl -U *100#
Press ESC and type ‘:wq!’ to save the script.
Add execution rights:
chmod +x /etc/yourscript.sh
Add script to crontab:
0 6 * * * /etc/yourscript.sh
Thank you dude!
Adding backslash didn’t help but using scripts works fine!
I’ve made only a little correction inside the script: #!/bin/sh (instead of bash)
Thanks and regards!
Dominik
