URL based interface selection
Hey folks,
I use an RUTX50. Can I create a rule where some URL’s uses a defined Interface no matter what the load balancer would decide?
Like www.google.com always uses WAN Interface and www.microsoft.com always uses MOBILE interface.
thanks in advance,
Andy
I found a working solution for me based on this tutorial:
https://wiki.teltonika-networks.com/view/LAN_Traffic_Splitting_Using_Advanced_Static_Routing_Rules
I just modified the routes accordingly. Okay I can not use the URL but for the moment I’m okay with an IP-Adress based routing.
It’s great to hear that you’ve found a solution, and thank you for sharing it with us here.
