UPS, USB connection and NUT
Hi
Is it possible to connect the Rutx09 to a UPS with USB monitoring and load the NUT server on Rutx09 so that I can monitor the battery status etc?
Sure, install nut-server:
opkg -e /etc/opkg/openwrt/distfeeds.conf install nut-server nut-driver-usbhid-ups
Thanks again - will give this a go tomorrow.
Sorry, quick question before I get started. Will firmware updates wipe all the work I am about to do and mean I need to do it all again?
Yes. Put the name of the files you want to preserve across a firmware update in /etc/sysupgrade.conf
Good afternoon,
I can see that @flebourse has kindly provided you with a method to answer your query.
Please after testing, advise if you need any further assistance.
Arturas
Thank you, kindly help me find the files that should be protected from a firmware update
To date i have added
/etc/config/nut_server
/etc/nut/
/etc/config/nut_cgi
/etc/config/ups
/etc/config/nut_monitor
/etc/config is in the default list no need to add it there.
/etc/nut only contains links to autogenerated files no need to protect them either.
You’ll have to reinstall the nut packages after a firmware update.
