I have a few hundred RUT241’s running RUT2M_R_00.07.06.10. These have a OpenVPN Client and I need to modify OpenVPN client’s .crt and .key via command line, how can I it? It needs to be a ssh/scp solution!
Thank you.
Thank you.
To modify your OpenVPN client’s certificate or key files through SSH, follow these steps:
cat /etc/config/openvpn
Look for the option key
and option cert
parameters in the output—these will show you the paths to the certificate and key files on the router. Copy these paths for use in the next step.
vi /etc/<path>
For example, it might look something like this:
vi /etc/vuci-uploads/cbid.openvpn.client.certclient.cert__1_.pem
In the vi
editor, press i
to enter insert mode and make your changes. Once done, press Esc
and type :wq
to save and exit.
Perfect, it works!
Thanks for your reply.
Great to hear that it worked! If you have any further questions or need additional assistance, feel free to reach out.
