Updating bootloader and firmware of RUT955
Hi, I have a RUT955 router which runs the latest release of the legacy firmware (RUT9XX_R_00.06.09.5).
I am looking to upgrade it to the new RutOS firmware (RUT9_R_00.07.xx.x). To do that I need to update its bootloader first (current bootloader version 3.2.5) as per the instructions in Teltonika’s documentation, “RUT9xx Firmware via The Bootloader Menu”:
Note: Using Legacy bootloader (RUT9XX_R_00.06.09.5 and lower), it is not possible to upgrade to RutOS RUT9 firmware (RUT9_R_00.07.00 and higher).
Other pages in Teltonika’s documentation, such as “Bootloader menu” and “RUT955 Device Recovery Options”, state that firmware and bootloader image files can be downloaded from this page: “RUT955 Firmware Downloads”. However, only firmware files are available on that page.
Where can I download the current bootloader for RUT955, so that I can then update its firmware? Thank you very much in advance.
Information on the router’s label:
RUT955T033F0
Batch no: 092
Serial: 1108563897
Information in LuCI:
Firmware and bootloader versions
Your current bootloader version should support the latest RutOS versions. Please try updating to it using the WebUI.
If that does not work, please upload a screenshot of the error you’re receiving.
The message
only applies to the firmware installed via the bootloader, WebUI uses different validation mechanisms.
