If i have 2 eSIMprofiles, and i disable the first eSIM profile and enable the second profile, the data used doesn’t show in the set datalimit because the data limit is set at the mob1s2a1e1 level, not at the level of any of the (maximum) of 7 eSIM profiles.
Of course this also shows when requesting the data_used via api get /data_limit/status.
Apologies for the delay. Could you please confirm whether the issue you’ve described — where the data usage is not reflected correctly in the set data limit when switching between eSIM profiles (as the data limit is applied at the mob1s2a1e1 interface level) — is still present after updating to the latest 7.14.2 firmware release.
