I am using a RUT951 as an OPC UA client to read data from a Turck PLC (TBEN-L4-PLC-11).
Issue:
The RUT951 cannot read STRING values. The result is always empty.
Other data types such as BOOL, INT, and REAL are working correctly.
I have tested the same OPC UA server using UAExpert, and STRING values are read correctly.
Question:
Is this a limitation of the RUT951 OPC UA client, or is it a known issue?
Is there any configuration or workaround to read STRING values?
Firmware version: RUT9M_R_00.07.22.1
Firmware build date: 2026-04-09
