Unable to connect to the internet with static IPv4 (FW 7.04.3)
Hello there,
I have troubles connecting my modem to the Internet.
I have double checked the APN settings and connected the support from A1 and from their side everything is correctly configured.
Inserting the same sim-card into another modem works perfectly fine with the same settings.
So any ideas what to try next?
Device: TRB245
Firmware: TRB2_R_00.07.04.3
Internal Modem FW: EC25EUXGAR08A05M1G_01.001.01.001
due to strange rules i needed to replace the APN in the logs from fixip.a1.net to fixip(dot)a1(dot)net
Log output:
Thu Jul 27 12:11:03 2023 kern.info kernel: network configuration has been changed
Thu Jul 27 12:11:03 2023 daemon.info mobifd: [gsm.modem0] Config reload initiated
Thu Jul 27 12:11:05 2023 daemon.info mobifd: [gsm.modem0] SMS storage: sm
Thu Jul 27 12:11:05 2023 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with 5 seconds of timeout
Thu Jul 27 12:11:05 2023 daemon.info mobifd: [gsm.modem0] Connected to operator ‘A1’
Thu Jul 27 12:11:06 2023 daemon.info mobifd: [gsm.modem0] -CFUN- Functionality: “Full”
Thu Jul 27 12:11:06 2023 daemon.info mobifd: [gsm.modem0] -COPS- Mode: “Auto”, operator: “A1”
Thu Jul 27 12:11:06 2023 daemon.info mobifd: [gsm.modem0] -CREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “zzzz”, cell ID: “yyyyyy”, technology: “E-UTRAN”
Thu Jul 27 12:11:06 2023 daemon.info mobifd: [gsm.modem0] -CGREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “zzzz”, cell ID: “yyyyyy”, technology: “E-UTRAN”
Thu Jul 27 12:11:06 2023 daemon.info mobifd: [gsm.modem0] -CEREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “zzzz”, cell ID: “yyyyyy”, technology: “E-UTRAN”
Thu Jul 27 12:11:06 2023 daemon.info mobifd: [gsm.modem0] IP address on PDP context “1”: “xxx.xxx.xxx.xxx”
Thu Jul 27 12:11:06 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is setting up now
Thu Jul 27 12:11:06 2023 daemon.notice netifd: mob1s1a1 (1132): wwan[1132] Using wwan usb device on bus 1-1.4
Thu Jul 27 12:11:07 2023 daemon.notice netifd: mob1s1a1 (1132): wwan[1132] Using proto:qmi_wwan device:/dev/cdc-wdm0 iface:wwan0 desc:Quectel EC25
Thu Jul 27 12:11:08 2023 daemon.notice netifd: mob1s1a1 (1132): Quering active sim position
Thu Jul 27 12:11:08 2023 daemon.notice netifd: mob1s1a1 (1132): Using net device: wwan0
Thu Jul 27 12:11:08 2023 daemon.notice netifd: mob1s1a1 (1132): Informing driver of raw-ip for wwan0 …
Thu Jul 27 12:11:09 2023 user.notice root: uqmi -d /dev/cdc-wdm0 --timeout 3000 --wda-set-data-format --link-layer-protocol raw-ip --ul-protocol disabled --dl-protocol disabled
Thu Jul 27 12:11:09 2023 daemon.notice netifd: mob1s1a1 (1132): Starting network mob1s1a1 using APN: fixip(dot)a1(dot)net
Thu Jul 27 12:11:09 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,6 --release-client-id wds --modify-profile --profile-identifier 3gpp,1 --profile-name profile1 --roaming-disallowed-flag yes --username ppp@a1plus.at --password ppp --auth-type pap --apn fixip(dot)a1(dot)net --pdp-type ip
Thu Jul 27 12:11:09 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --get-client-id wds
Thu Jul 27 12:11:10 2023 daemon.notice netifd: mob1s1a1 (1132): 6
Thu Jul 27 12:11:10 2023 daemon.notice netifd: mob1s1a1 (1132): cid4: 6
Thu Jul 27 12:11:10 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-ip-family ipv4 --set-client-id wds,6
Thu Jul 27 12:11:10 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,6 --start-network --apn fixip(dot)a1(dot)net --profile 1 --auth-type pap --username ppp@a1plus.at --password ppp
Thu Jul 27 12:11:10 2023 daemon.notice netifd: mob1s1a1 (1132): pdh4: “No effect”
Thu Jul 27 12:11:10 2023 daemon.notice netifd: mob1s1a1 (1132): Unable to connect IPv4
Thu Jul 27 12:11:10 2023 daemon.notice netifd: mob1s1a1 (1132): Releasing client-id 6 on /dev/cdc-wdm0
Thu Jul 27 12:11:10 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,6 --release-client-id wds
Thu Jul 27 12:11:10 2023 daemon.notice netifd: mob1s1a1 (1132): Failed to create IPV4 connection
Thu Jul 27 12:11:21 2023 daemon.notice netifd: mob1s1a1 (1451): Stopping network mob1s1a1
Thu Jul 27 12:11:21 2023 daemon.notice netifd: mob1s1a1 (1451): Command failed: Not found
Thu Jul 27 12:11:21 2023 daemon.notice netifd: mob1s1a1 (1451): Command failed: Permission deniedw
Thu Jul 27 12:11:21 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is now down
Thu Jul 27 12:08:22 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is setting up now
Thu Jul 27 12:08:23 2023 daemon.notice netifd: mob1s1a1 (30631): wwan[30631] Using wwan usb device on bus 1-1.4
It seems that you are able to connect to the operator, but there is an issue with IPv4 network.
Could you try changing PDP type? For this, navigate to Network → Interfaces → Edit mob1s1a1 interface and change PDP type from IPv4 to IPv4/IPv6.
Let me know if it connects then.
thank you for the reply. Unfortunately, the suggestion to change the PDP type does not help.
And I also need a static IPv4 address.
After an update to FW 7.04.5 the error still remains.
Mon Jul 31 09:35:05 2023 daemon.info mobifd: [gsm.modem0] SMS storage: sm
Mon Jul 31 09:35:05 2023 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with 15 seconds of timeout
Mon Jul 31 09:35:05 2023 daemon.info mobifd: [gsm.modem0] Connected to operator ‘A1’
Mon Jul 31 09:35:05 2023 daemon.info mobifd: [gsm.modem0] -CFUN- Functionality: “Full”
Mon Jul 31 09:35:05 2023 daemon.info mobifd: [gsm.modem0] -COPS- Mode: “Auto”, operator: “A1”
Mon Jul 31 09:35:05 2023 daemon.info mobifd: [gsm.modem0] -CREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “zzzz”, cell ID: “yyyyyy”, technology: “E-UTRAN”
Mon Jul 31 09:35:05 2023 daemon.info mobifd: [gsm.modem0] -CGREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “zzzz”, cell ID: “yyyyyy”, technology: “E-UTRAN”
Mon Jul 31 09:35:05 2023 daemon.info mobifd: [gsm.modem0] -CEREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “zzzz”, cell ID: “yyyyyy”, technology: “E-UTRAN”
Mon Jul 31 09:35:05 2023 daemon.info mobifd: [gsm.modem0] IP address on PDP context “1”: “xxx.xxx.xxx.xxx”
Mon Jul 31 09:35:05 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is setting up now
Mon Jul 31 09:35:06 2023 daemon.notice netifd: mob1s1a1 (16045): wwan[16045] Using wwan usb device on bus 1-1.4
Mon Jul 31 09:35:07 2023 daemon.notice netifd: mob1s1a1 (16045): wwan[16045] Using proto:qmi_wwan device:/dev/cdc-wdm0 iface:wwan0 desc:Quectel EC25
Mon Jul 31 09:35:09 2023 daemon.info dnsmasq[3145]: read /etc/hosts - 4 addresses
Mon Jul 31 09:35:09 2023 daemon.info dnsmasq[3145]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Mon Jul 31 09:35:09 2023 daemon.info dnsmasq-dhcp[3145]: read /etc/ethers - 0 addresses
Mon Jul 31 09:35:10 2023 daemon.notice netifd: mob1s1a1 (16045): Quering active sim position
Mon Jul 31 09:35:10 2023 kern.info Mobile data disconnected (internal modem)
Mon Jul 31 09:35:10 2023 daemon.notice netifd: mob1s1a1 (16045): Using net device: wwan0
Mon Jul 31 09:35:10 2023 daemon.notice netifd: mob1s1a1 (16045): Informing driver of raw-ip for wwan0 …
Mon Jul 31 09:35:11 2023 user.notice root: uqmi -d /dev/cdc-wdm0 --timeout 3000 --wda-set-data-format --link-layer-protocol raw-ip --ul-protocol disabled --dl-protocol disabled
Mon Jul 31 09:35:11 2023 daemon.notice netifd: mob1s1a1 (16045): Starting network mob1s1a1 using APN: fixip(dot)a1(dot)net
Mon Jul 31 09:35:11 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,5 --release-client-id wds --modify-profile --profile-identifier 3gpp,1 --profile-name profile1 --roaming-disallowed-flag no --username ppp@a1plus.at --password ppp --auth-type pap --apn fixip(dot)a1(dot)net --pdp-type ip
Mon Jul 31 09:35:12 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --get-client-id wds
Mon Jul 31 09:35:12 2023 daemon.notice netifd: mob1s1a1 (16045): 5
Mon Jul 31 09:35:12 2023 daemon.notice netifd: mob1s1a1 (16045): cid4: 5
Mon Jul 31 09:35:12 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-ip-family ipv4 --set-client-id wds,5
Mon Jul 31 09:35:12 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,5 --start-network --apn fixip(dot)a1(dot)net --profile 1 --auth-type pap --username ppp@a1plus.at --password ppp
Mon Jul 31 09:35:12 2023 daemon.notice netifd: mob1s1a1 (16045): pdh4: “No effect”
Mon Jul 31 09:35:12 2023 daemon.notice netifd: mob1s1a1 (16045): Unable to connect IPv4
Mon Jul 31 09:35:12 2023 daemon.notice netifd: mob1s1a1 (16045): Releasing client-id 5 on /dev/cdc-wdm0
Mon Jul 31 09:35:12 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,5 --release-client-id wds
Mon Jul 31 09:35:12 2023 daemon.notice netifd: mob1s1a1 (16045): Failed to create IPV4 connection
Mon Jul 31 09:35:23 2023 daemon.notice netifd: mob1s1a1 (16527): Stopping network mob1s1a1
Mon Jul 31 09:35:23 2023 daemon.notice netifd: mob1s1a1 (16527): Command failed: Not found
Mon Jul 31 09:35:23 2023 daemon.notice netifd: mob1s1a1 (16527): Command failed: Permission denied
Mon Jul 31 09:35:23 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is now down
Mon Jul 31 09:35:23 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is setting up now
Mon Jul 31 09:35:24 2023 daemon.notice netifd: mob1s1a1 (16551): wwan[16551] Using wwan usb device on bus 1-1.4
Mon Jul 31 09:35:24 2023 daemon.notice netifd: mob1s1a1 (16551): wwan[16551] Using proto:qmi_wwan device:/dev/cdc-wdm0 iface:wwan0 desc:Quectel EC25
