Hi all,
I’m bumping my head around this problem…that is, accessing the web interfaces of applications behind RUTX50 from outside via browser (https) is extremely slow with a lot of pages/js going to error 200 or HTTP_ERROR_X etc.
Few details:
RUTX50 interface is perfectly accessible from outside via RMS at normal speed (RUTX50 speedtest reports 70Mb/35Mb) and CLI interfaces to internal servers work flawlessly at normal speed
accessing internal sites via https (via RMS) is painfully slow and doesn’t work partially or at all
RUTX50 has an openvpn connection that provides hostname/static ip accessible from outside. It worked so far, and it works now. Disabling it doesn’t change the problem.
Accessing applications https interfaces from inside (same network) works normally
Needless to say, since two days ago, everything worked perfectly, and nothing has been changed in the router config (as far as I can see)
I really can’t figure out the reason. Any help is really appreciated.
