I have two queries regarding UL202 Ultrasonic Fuel Sensor.
First one is can I use two UL202 sensor with single FMC125 or not?
Second one is I want to use UL202 with two different tanks:
For Fuel tank height 1.5 ft. and wall thickness of fuel tank 3 mm
For Water tank height. 5 ft. and wall thickness of water tank 8 mm
UL202 can monitor both tanks or not? if not, what are the options to do that.
For the point 2
This will require POC, or you may need to visit the site to conduct tests. Alternatively, you can confirm this information with the sensor manufacturer.
